vaccum leak check
Re: vaccum leak check
The messy way of checking for a vacuum leak is by running the motor and spraying carb cleaner around the intake or where you might think there is a leak. Youll know if you found one when the idle picks up for a sec. burning off the carb cleaner.
The other way is to seal off the throttle body and then hook up a vacuum gauge and pump to create a negative pressure inside the intake. Then you watch the gauge to see if the pressure increases after 5 minutes or something.
the LT1 only has a vacuum ports on the manifold. I would check each of them (EGR, HVAC, a few other i cant remember are on the IM). The TB has the EVAP and whatever. Check each system part by part. You need a vacuum gauge (~30 bucks) and watch guage. if the pressure drops fast then you have a leak.
teal98
15
09-16-2002 01:23 PM
danielbmx
08-27-2002 11:11 PM
johnsocal
21
08-17-2002 01:06 AM
SilverWS6
13
08-14-2002 09:29 PM
newby
10
07-27-2002 11:39 AM
