Vacuum canister.
Vacuum canister.
What all does the stock vacuum canister supply. I've deleted my HVAC, is that the only thing? Just wondering if I need to remove it or plug the vacuum lines or what.
Re: Vacuum canister.
The only vacuum line I saw in the main harness comes from the intake manifold to supply vacuum canister and HVAC system and has a check valve inline. I can't think of anything else that is vacuum operated.
95z_28_camaro_4_Ivan
10-03-2015 07:27 PM
