Vacuum problem regarding my brakes
Apparently I have a problem with my brakes because I don't have enough vacuum pressure because I installed a COMP CAM 306 in my 96 LT1. I have heard I need a booster for the brake booster. Can someone tell me what I need to do to help solve my problem?
Re: Vacuum problem regarding my brakes
I have exactly the same problem. If I am rolling in gear and slam the brakes they grab good, but if I am idling up to a light and slam them they suck bad. I also have the 306 and have checked for leaks. Is there any aftermarket vacum booster that people have had good luck with that is inexpensive?
Put a vacuum can on it. Ya won't be able to repeatedly hit the brakes at idle.If ya got 10in of vacuum and a can your breaks should worh fine.
I have done this on a pickup towing a 26' boat and no problems stoping.
dluna333
15
03-13-2015 12:30 PM
