valve cover height with new 1.6 rockers
I am looking to finish a build of my car and will be running ported stock heads with PAC beehives and comp 1.6 3/8 pro mag rockers. I am trying to figure out if I need new valve covers to run this setup. And if I do does anyone know of something besides the canton valve covers?
Does that mean grinding all the baffles? I read somewhere the poly locks are also a height issue. I've also read the Cantons are problematic with the pro mags.
http://www.chevyhiperformance.com/te.../photo_12.html
That is how I did mine and it clears perfectly and does not leak.
My CC 1.6 RRs tapped on my Cantons, all I had to do was loosen the valve cover bolts a bit and that was enough to completely clearance the rockers. Cantons are my favorite engine appearance mod yet, I would recommend them to anyone.
Was looking for an aftermarket valve cover and stumbled onto this thread. Was looking for a nice set of black high covers to clear the pro mag ultra's. I'm not impressed with anything so far so I'll just mod the stockers and save the coin for a functional mod.
That doesn't sit too well with me. For almost $200 for those Cantons you shouldn't have had to do that IMO.
Well this is really irrelevant since I already have the car back together and running. I just ran the stock covers and ground out part of the bracing. The metal was so thin i could use tin snips. The baffle was punched out and I had to create a smaller one that is held in with a rivet. Thanks though!
