valve covers for stud rockers and afr heads
what choice is there for tall valve covers that need clearance for shaft rockers, etc?
i see moroso makes some very nice but expensive tall centerbolt valvecovers http://store.summitracing.com/partde...OR-68026&N=120 303646
then i run across these on ebay: http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
does anybodyhave any experience with these?
im looking for some tall affordable valvecovers, any suggestions?
my alternator is relocated, so that isnt a factor
thanks
thanks
Re: valve covers for stud rockers and afr heads
They don't necessarily need to be a whole lot taller than stock to work. They do however need to be wider cause the pushrod side of the rocker may very well come into contact with the cover. I saw a guy last weekend who was using the LT4 composite covers with a shaft setup. Maybe they're a little wider... I don't really know. But I think that any cover with another 1/4"+ of height and a bit more width should work fine with shafts. Thicker aluminum covers would be better IMO because they have enough beef that you could do a little grinding on the inner walls if you needed. That and using a profiled-tail rocker will help.
-Mindgame
-Mindgame
What about these http://www.gmpartsdirect.com/results.cfm put in part number 12497985.
i was looking for something a little different than the GM 12497985, thanks though...
i like the style of the moroso's, is there anymore options out there?
These companies make centerbolt sheetmetal covers and I'm sure there are others...
Scoggin Dickey
Billet Fabrication
Doug Herbert
Moroso
-Mindgame
Scoggin Dickey
Billet Fabrication
Doug Herbert
Moroso
-Mindgame
95chwagon
01-13-2015 09:19 PM
