which valve springs
which valve springs
CAM: 224/236 .605/.622 with 1.6 SA Pro Mag RR
I broke some piece of sh*t cm 612's. Im wanting to keep stock diameter so I dont have to pull the heads off.
Thanks,
Waylon
Thanks,
Waylon
The springs guys are telling you to use will get beat up in just a few thousand miles.
Tht lobe is irresponsibly aggressive for street use and you are going to need even more spring.
wrd1972 battles this recently and has a good thread in the archives from just a few months back, had it "resolved" for now at least but no long term results on the spring he settled on yet.
Do a search, find that thread, it will help.
Check your other post. I would say try the Crane 99893 springs and install them at 1.80" (150# closed). At 1.80" installed height the Cranes are good to .650". If they don't hold up then you should consider Manley NexTeks or another equivalent spring. If you still have trouble I'd switch to 1.5:1 rockers.
