Valve springs on trick flow heads good with 224/230 cam?
#16
I believe my AFR's have the big block beehives setup @ 150 on the seat (set up by LE).
#17
I believe you are talking about the 26120 beehives, these require longer valves to have the right spring pressures/installed height. Thats the information I got when setting up my valvetrain.
#18
Springs (Comp # 29120) set up at 1.880 and have 155 lbs on the seat
65 cc chambers
214 cc intake port
oldschool
02-09-2016 09:21 PM
