vats wiring
Old 03-06-2005 | 01:11 PM
gillt1's Avatar
Question vats wiring
Has anyone have picture of wiring vats bypass module? I have schematic but donot understand taht well. Thank You.
Old 03-06-2005 | 01:17 PM
RE AND CHERYL's Avatar
Re: vats wiring
It's actually pretty easy. Use a miltimeter to measure the resistance in your key. Get a resistor that matches the resistance of your key and tap it into the wires going to the vatts contacts in the ignition lock.
Why do you want to bypass it??
Old 03-06-2005 | 02:10 PM
gillt1's Avatar
Re: vats wiring
Maybe I worded my question incorrectly. I purchased vats bypass module form Bakerelectronix. ,they sent a wiring schematic , but I cannot understand diagram, this why I would like picture of diagram. Thank You in advance.
Old 03-06-2005 | 09:36 PM
Re: vats wiring
Without seeing their diagram, it's a little hard to know exactly what they are telling you. I assume you don't mean the key pellet bypass, but the VATS module bypass (that simulates the modulated ground signal to the PCM).
Old 03-07-2005 | 06:48 PM
gillt1's Avatar
Talking Re: vats wiring
Thanks all ,I did some research and found what I needed
Heathen1
01-02-2016 04:27 PM
Klypto
03-09-2015 04:25 PM
Noer
02-28-2015 11:29 AM
Lakebratt
02-05-2015 07:55 PM
Fedesna
11-23-2014 11:06 AM
Quick Reply: vats wiring
