venom computer module
venom 400 performance control module
so whats the deal with the venom comp module? it advertised 25% hp&tq increase. will it do it? is it worth the money? is it better than a stage 2 chip? thanks.
Re: venom computer module
Originally Posted by mourningyou
it's probably just a maf translator or intake air temp box, but after reading it more closely, it looks like it just makes power enrichment mode come on much easier.
the pe mode is enabled by the tps, so thats not it, but i think your right about maf translator
if your going to buy anything pcm now days you might as well just buy tunercat and be done with it you can get tunercat and the cable for 165 and do a 1000 times more things than that peice of crap.
Originally Posted by Venom PCM Link
The Venom 400 activates at about 25-30% throttle angle. Upon activation it modifies the input signals going into your computer, in particular the Manifold Absolute Pressure and Throttle Position Sensor Signals.
its just a maf translator and a pe translator. lets you use PE mode with the throttle blades more closed. probably wastes a ton of gas :P
