Vibration 3000 rpm +
My engine is internally balanced. I feel a vibration after 3000 RPM. After I changed my first clutch Spec 3, I simply replaced with a Spec 3+. Do these clutches came balanced? Could that be the reason of vibration?? If so when I take out the clutch, it vibration will be dissapear? Or could my engine messed up ?
Hope you understand my english
Deniz
Deniz
No I didn't remove the flywheel. I just get a new friction plate and replace it. I only swap the clutch. This makes sense? Or do I have a vibration issue related to another thing ? Misfire ?
