Video of me at the track.
#16
#18
what kind of horse power are you running, just curious what you did to make it that fast.....thats exactly why I bought another pony car while everyone else seems to be going japanese, when you want fast, you get fast!!
#19
Ported heads, Ported intake manifold, 58mm TB, 32lb injectors, Jethot headers, True duals, U/D pulley, and one of the most important things, a dyno tune.
#20
I haven't gotten it on the dyno with the new set, well I did but I was getting vavle float and I'm pretty sure I fixed it. So I have no idea. As far as the other mods, I have all the usual stuff,
#21
Well since this is back to the top, heres what my heads flowed when I ran those times.
.2 132/104
.3 186/127
.4 226/158
.5 243/164
.6 238/169
They are currently being turned into LE2 heads.
.2 132/104
.3 186/127
.4 226/158
.5 243/164
.6 238/169
#22
I don't believe those flow numbers at all for turning 118mph trap speeds with a power peak past 6000rpm unless there's something you aren't telling us...
#23
http://www.putfile.com/pic.php?img=4756660
http://www.putfile.com/pic.php?img=4756661
http://www.putfile.com/pic.php?img=4756662
http://www.putfile.com/pic.php?img=4756663
http://www.putfile.com/pic.php?img=4756664
http://www.putfile.com/pic.php?img=4756665
#24
Those are the flow #'s. Stock pistons, bore, stroke, ect, and a stock waterpump. Heres the pics of the ports, there isn't that much done to them...
Those things do look pathetic. Its amazing you got what you did out of them.
#26
#27
Interesting that it is very rare for cars at least on this website cannot trap above 116mph with reputable heads/cam combos where the heads have reportedly flowed 280+cfm and dynoed 39x/4xxrwhp... It seems nowadays the running norm is having to dyno at least 420rwhp in order to run anwhere close to 118-120mph through the traps.
If you haven't realized it yet there's always an untold story when it comes to modifying, the dyno, the flow bench and racing whether it be from the person or the components.
demon
What's your race weight?
demon
#28
demon
demon
#29
Man the VJ on those heads you can tell works like crap, the intake ports being as black as they are. The entry is all jacked up as well along with a bad guide area, I don't even want to see the short turn. I believe they flowed that easy.
I'm with Javier it's a big conspiracy, it's just like the pushrod conspiracy. Especially those results from Crane with the 240lbs springs over the nose on the 214 .440" cam gaining 12hp with real pushrods. They all just make this **** up.
Bret
Bret
#30
The Probably ~3600, it only has the !spare/jack and !back seats, but then I have 17x9's up from and 17x11's out back, SFC's, C5 brakes up front, and a bigass becool radiator, so its basically a full weight car, all power everything ect. I posted pics of the timeslips and a video of me at the track, what more do you want? I'm suprised it ran as hard as it did, but track #'s don't lie. And it was at the gainesville dragstrip, they the gator nationals their so it's not like its some ghetto track with the timing equipment all screwed up.
Bret... you're such a woman. Get over it. I agree with most everything you've stated except for the fact that you believe ALL hardened pushrods and Comp R's are junk. Do I have to agree with everything you say in order for you to stop whining? As far as gaining 12hp that could've happened with something as simple as an engine temperature variation. Too many variables to just outright believe that small of a hp increase.
The bottom line is I posted a link to some cheap hardened pushrods that WORK for mild applications. Please refrain from ****ting up this thread with your estrogen filled comments.
