Voltage Flicker Help!
I have a few problems. When I am idling with the interior lights, the lights get bright and then dim. The amp meter varys from 13-15 volts At WOT above 4400 to redline the lights dim and the voltage drops down to about 11 then when I shift it goes back to normal. Also, sometimes when I drive, the voltage flicker. Any help would be appreciated
08-07-2015 01:26 PM
