VRE-Project 1994 Supercharged Trans Am
Old 08-21-2006, 09:37 AM
Eric@Victory Racing's Avatar
This project consisted of transforming this 1994 Trans Am daily driver into a winner at the strip. It came to us with blown engine from the Powerdyne it previously had. We built a fully forged 355ci engine to accomidate the 20# of boost, from the new Vortech supercharger the customer(cjmatt) would like to run. The short block consisted of a Callies Dragonslayer crankshaft, Compstar connecting rods, and Diamond Pistons. We finished it off with a LT1 mainfold, unported LT1 cylinder heads, ATI damper and CSI electric water pump.
We dynoed this past Saturday and were very pleased with the results 518/467 at only 10psi. Plans are to upgrade the fuel pump from a single 255lph to the dual in-tank setup, and then put on the smaller pulley.
Eric@Victory Racing is offline
Old 08-21-2006, 09:41 AM
Fastbird93's Avatar
Re: VRE-Project 1994 Supercharged Trans Am
Wow. On unported heads.......dang. That thing would probably pick up a gargantuan amount of power with ported LT1 castings much less anything else. Looks like you've put together a VERY nice combo.
Fastbird93 is offline
Old 08-21-2006, 09:56 AM
JustNO's Avatar
Its also a Mustang dyno! Great Power!
JustNO is offline
Old 08-21-2006, 11:36 AM
T/A KID's Avatar
What cam is in that thing Eric?
T/A KID is offline
Old 08-21-2006, 11:42 AM
bowtiepwr's Avatar
>nice numbers... you guys did the install?
bowtiepwr is offline
Old 08-21-2006, 12:51 PM
It was one of Bret's. Off hand I don't remember the specs.
Old 08-21-2006, 12:52 PM
Our facility was going to do the install, but could not fit it in. The customer ended up having a friend do it.
Old 08-21-2006, 03:45 PM
kainZ's Avatar
How much was the whole build?
kainZ is offline
Old 08-21-2006, 03:50 PM
Pm Sent
Old 08-21-2006, 06:16 PM
BIG SHAFE's Avatar
What compression ratio are you running? I'm guessing you used an aftermarket ECU?
Thanks.
BIG SHAFE is offline
Old 08-21-2006, 06:22 PM
9.0:1
Old 08-21-2006, 06:25 PM
Josh'95Z28conv's Avatar
Dang, maybe I should have done that build instead of mine. I bet the price was about the same. At least I should have more power when I spray though.
Hella nice #'s.
Josh'95Z28conv is offline
Old 08-21-2006, 06:30 PM
BIG SHAFE's Avatar
Originally Posted by Eric@Victory Racing
9.0:1
Cool thanks, any estimate on the power output for 20 psi?
Old 08-21-2006, 06:41 PM
I don't have any predictions yet. I will be sure to post results after the changes are made and we dyno it again.
Old 08-21-2006, 07:47 PM
I talked to the customer today.He wants to try it again with the stock heads and see what kind of power numbers we come up with. Eventually he will probably do a set of ported heads, port matched intake, and 58mm throttle body.
Quick Reply: VRE-Project 1994 Supercharged Trans Am
