want to upgrade
Re: want to upgrade
Depends on the budget.
Throttle body coolant bypass.Cheap.I haven't done this yet,and I'm so ashamed,but will get around to it.Good for 6-7 ponies.
Cat back system.About ten hp I think
Cold air system.I would do this first.About 10 hp I think
Decent tires.Hard to find ones for the 16 inch,but I'm happy with my coopers.
Zeon RS3-A.Some vette folks run them.They are predictable and hold pretty well.I used to run firestone sz50's, but I like these better.
Why don't you post a signature it's real easy.
NGk spark plugs.Used to run the non plats, but got tired replacing them all the time so I run the plats.Super happy here.Other members like the iradium plugs.
The coil wire is the weak link in the chain,so I would replace that often.
Hope this helps.Beer time.
Re: want to upgrade
CAT back exhaust
Cold air intake system
PCM tune (use a 160 T stat)
new, better valve springs
1:6 RR
3:73's
2600 RPM stall TC
Re: want to upgrade
Re: want to upgrade
Easy ,just go up to UserCP left hand corner of the page and click on it and you can describe you car like stick or auto trans,any mods done,hard top or convert.Then every time you post something,it will show up at the bottom of your message,so folks can better help out.Hope this helps.
Re: want to upgrade
heres your list:
LLP stainless headers 1 3/4 (mention LS1tech for discount)
Pacesetter y-pipe
PCMforLess tune
Cold Air Intake of your choice
should be under budget and a huge performance bump
Pacesetter y-pipe
PCMforLess tune
