washed lt1 and now...
Old 10-03-2013 | 02:31 AM
nikatil's Avatar
so I have a 1994 z28 m6 ..had a few leaks I couldn't find ...power steering
oil and coolant...washed it fixed leaks it wouldn't run for 3 days ...now I drove it for 3 blocks it ran fine then back fire in the intake if you touch gas..high idle and runs soooooo rough...I know I got opti wet but if I broke it I would need to replace it because it wouldn't run at all right? also cleaned all sensors top and bottom..and I have a code light and no scanner
Old 10-03-2013 | 04:25 AM
Chet1185's Avatar
Re: washed lt1 and now...
Since you got it wet, I would replace it. My pin to drive the opti was to short and it still ran.
Sent from my R800x using Tapatalk 2
Old 10-03-2013 | 09:02 AM
nikatil's Avatar
don't know it its wet....wet ones have no spark yah?
Old 10-03-2013 | 09:15 AM
Chet1185's Avatar
I'm not an expert in how they work but I know if mine was wet it would be replaced.
Old 10-03-2013 | 12:48 PM
What does "washed it" mean? Without a way to scan you have to guess. My best advice is to get a scan solution.
Old 10-03-2013 | 06:49 PM
Mr99SS's Avatar
only way id wash an lt1-4 car with opti was to put a bag over it and use the small steam machines like u see on tv witch walmart sells online ..
Old 10-04-2013 | 06:25 AM
nikatil's Avatar
solved!!! plug on top of opti was full of oil/water cleaned connection and it rapes!!
91Bird305
03-27-2003 12:52 AM
Hot Rod Hawk
08-30-2002 10:12 PM
Mary94Z28
08-10-2001 12:19 PM
josh99ta
08-06-2001 06:19 AM
madwolf
08-02-2001 08:32 AM
Quick Reply: washed lt1 and now...
