Washer Seals aournd the Reverse Coolant Bolts????
Do they have to be on each side? Can I get away with using a little silicone on one side? Also if I need one is this a direct GM Item only?
I got mine from combantion motor sports but I would say your local parts store has them and yes they have to be on both sides you could try silcone but I would just get the gaskets.Dont want to clog the whole's up...
Re: Washer Seals aournd the Reverse Coolant Bolts????
