water pump
water pump
Hello everyone, thinking about changing water pump to an electric one...was wondering what to do with the temp sensor,will i throw a check engine light? didnt see where to install temp sensor on elec pump.
Re: water pump
You still use the sensor. You use your original LT1 waterpump housing you just remove the center section along with the impeller...the electric water pmp then bolts on to the housing...you may have to mod the housing for it to fit right.
Blood type Z28
04-08-2015 11:34 PM
