Water Pump Gear Sleeve Question!
Is there a certain way this has to go on? It looks like it's the same on both ends inside. But the out side has a ring at one of the ends. I took it off before I noticed this and was wondering which end the ring has to go on? The block or water pump? Thanks.
Re: Water Pump Gear Sleeve Question!
Originally Posted by Lyle A
Would it matter if it was backwards? 50/50 chance if you don't pay attention.
Well, I guilty of not taking note of that part of it. Might be right, might be wrong. If I pull it off to check, it will be right. If I leave it, it will be wrong. Right? Oh well. No worries.
10-31-2016 11:09 AM
