Water Pump Install Help...Quick
Trying to change my water pump right now but have a question. I drained all the coolant from the radiator but it was only about 1.5 gallons of it, where is the rest of the coolant at??? I thought the coolant capacity was around 4 gallons.
Help me please...how do I make sure to get all the coolant out....where exactly are the block drain plugs?? Thanks a lot.
you just need to twist and pull. I would check them to see what kind of condition they are in. If they look like they need to be replaced, take a razor blade or a box knife and just cut a slit in them where they connect to the pump and slide them off and get new hoses. Now would be the best time to replace them.
Can someone tell me how I get the AIR bracket off. I have all the bolts out of it and it seems to "wiggle" around but I can't pull it off, something is holding it back or catching on it. ANy ideas???
Got the pump finally off and quite for the day. Is there some secret to getting the old coolant temp sensor out of the old pump and into the new? ALso, how important is it to get rid of ALL the old gasket material. Thanks
umm, you can reuse the temp sensor but i would just run and and get a new one, y not, they are cheap and 1 less thing to worry about, i usally replace many parts when i do stuff like that on my car, if in doubt get a new one.
