Waterpump: Reman or brand new?
Old 01-24-2005, 08:27 PM
  #16
Z95m6's Avatar
Re: Waterpump: Reman or brand new?
Originally Posted by 96capricemgr
I would rather have the slow leak failure mode than the stop spinning like an electric. Opti wetting is not anywhere near as bad as many seem too think, mine has been doused a few times in Dexcool(another one of those things that gets an undeserved bad rap) and is fine. A tip for all is to take a little of that grease you get with plugwires and coat the weatherpack seal at the opti wiring harness, that is where it is most vulnerable to water getting in, the grease will help seal it up tight.
Good info. The reason i'm running my LT4 ED chain was because i don't trust the electric pumps, they go out instantly unlike manual pumps which usually leak a little bit before they go. Also if your electric pump goes bad you can't get one at the local parts house. The opti isn't as weak as everyone says.
Z95m6 is offline
Old 01-24-2005, 08:41 PM
  #17
hotrod18_69's Avatar
Originally Posted by Z95m6
Good info. The reason i'm running my LT4 ED chain was because i don't trust the electric pumps, they go out instantly unlike manual pumps which usually leak a little bit before they go. Also if your electric pump goes bad you can't get one at the local parts house. Also the opti isn't as weak as everyone says.
Couldn't agree more.
hotrod18_69 is offline
Old 01-24-2005, 09:42 PM
  #18
my94blackz's Avatar
Id the opti goes bad blame it on the water pump and if your good enuff the parts store will provide a new one
my94blackz is offline
Old 01-25-2005, 08:06 AM
  #19
JasonK94Z's Avatar
Thanks for the help guys!
JasonK94Z is offline
lt1xondeck
07-13-2015 09:03 AM
chevy95z28
06-22-2015 09:28 PM
97TA-WS6-Con
01-10-2015 05:31 PM
DETROIT_AREA_00_SS
08-14-2002 08:00 PM
Quick Reply: Waterpump: Reman or brand new?
