weird spark problem
weird spark problem
the car cranks up .. i can hear the crack turning over .. but there is no firing.
so i checked both passenger side and driver side for spark and guess what
Driver side gets normal spark
Passenger side has no spark at all !!!
i figured it might be a ground wire so i replaced that with a new one .. and it did not fix it.
before i changed the ground wire ... sometimes it would fire ok on passenger side but not on driver side .. then the reverse happens where it fires ok driver side but not passenger side .. some times both dont fire at all ...
it never fired normal on both sides...
What the heck is wrong with it !!!!?????
btw: new wires , new plugs , new ground wire , coil firing fine.
grabbem88
03-18-2015 01:25 PM
Magenta_Hearts
03-05-2015 07:01 AM
