Weird Voltage readings
The voltage reading on the dash seems to be a little screwy at times. The other day when sitting in a drive thru it dropped to almost red. The next day it was just under or over 13v. I went by Advance Auto and they did a load test and said the battery was bad and the alternator was good. I replaced the batter but it still reads right at 13v and sometimes on start up its under 13v with the air on. It eventually hits right at or just over 13v after running for a min. Could their load test on the charging system be incorrect and I have a bad alternator? It seems it should never be under 13v if its running. Thanks for the help.
Use a volt meter and measure the voltage with the car running directly from the back of the alternator. Just be careful when doing so. This will actually verify that the gauge is correct inside the car.
Car off it was 12.9 at the battery. Car running it was 14v at the alternator and 13.9 at the battery. Under a load it was 13.6 at the alternator and 13.5 at the battery. So guess its putting out what it should be. Can Alternators work sometimes correctly and not at others? or are they either good or bad not both sometimes?
I did that. That was the under a load reading. Straight running it was 14v at the alternator with the other stuff on it was 13.6. Thats why I asked if the could go bad and work properly sometimes but not others.
OK.. Its seems normal...... How old is the alternator???? If it changes again, it might be a bad regulator.. Its internal, so just get a new alt....
10-31-2016 11:09 AM
edman
01-22-2015 02:45 PM
z28projects4ever
9
07-16-2002 07:48 PM
