Well im half way done with my header install.
Like it says half way done and boy am i glad!! Removing the old exhaust was a major pain in the ***. Luckily no twisted bolts or anything of that matter. So tomorrow morning i will begin installing my Jet Hot LT's. Do you guys have any tips for the install? Wich was the hardest part for you? Installation of the new headers, or removal of the stock exhaust? Btw im going with true duals so no worring about a Y-pipe fitting up. Thx guys, Tyler
Last bolt on the passenger side SUCKS. Also, I didn't have my car up high enough, so I had to jack the engine up to get the passenger side header tube in. That and I had to mash the two wing things on the stearing shaft otherwise it would have hit the #1 tube.
If getting the headers in there start to drive you crazy dont be afraid to jack the engine up. Helped me a ton. The passenger side slides in fromt he bottom without jacking the engine up or removing the starter. At least it did with mine. I have Hooker LT's btw. Probably not much difference. Good luck and your gona love them. Especially after you race an LS1 with them on, hehe. Wakes the LT1's up big time on top-end.
94redform
09-08-2002 03:27 AM
