What 3000+ stall converters is everyone using?
Old 09-08-2003, 05:56 PM
12SCNDZ's Avatar
Ok, incase you missed my other thread. I've got a 10.5", 3200 stall ProTorque converter that's only stalling at 1900, on the footbrake. Since my CC305/ported head swap, I'm only pulling 1.77 60 ft. times (no wheelspin). My cam starts making power at 2500 RPM's, so 1900 stall isn't no where close to being enough. ProTorque says they can restall my 10.5" to stall more, but I'll lose top end MPH...Unless I set it up to lock up in 2nd gear. Or I can go with their 9.5" non lock-up, which will give me more stall, and efficiency, but it's not as "Street Friendly". I still drive this car on the street alot.
Here's what I want to know.
(1) What converter manufactuerer and stall rating you're using?
(2) What cam are you using...With cams advertised RPM range?
(3) What is your footbrake stall?
(4) What is your MPH and ET...Preferably N/A?
(5) What's your 60 ft. times
BTW, take notice that this is a '93 Camaro, so I've got a 700, not a 4L60E
Frank
12SCNDZ is offline
Old 09-08-2003, 06:06 PM
Transamdriver's Avatar
Re: What 3000+ stall converters is everyone using?
97 4L60E with Precision 3600.
CC306
Footbrake stall on stock internals was 3000
Best MPH was 105.6 stock internal with 2.1 60' so there was more MPH in it since I had to play the flutter the throttle game.
Transamdriver is offline
Old 09-08-2003, 07:00 PM
12SCNDZ's Avatar
Nobody else has any testimonials?
Frank
12SCNDZ is offline
Old 09-08-2003, 10:32 PM
allmotorta's Avatar
Frank
1. Coan 10", 3500
2. CC306 cam
3. footbrakes to only about 2000
4. 12.24 @ 112ish, 3305' DA, horrible air...
5. Consistent 1.70's.
When I start actually working on my car again (damn college ) I want to either have it restalled up about 500, or maybe toss in a whole new converter. Definitely want to footbrake up to 3000ish
allmotorta is offline
Old 09-08-2003, 11:17 PM
GhostZ's Avatar
Frank
Midwest 3200
Hotcam
Footbrake- Around 2400
13.36 @103 (Utah DA around 6000+ ft )
1.96 on street tires, 1.71 with ET Drags and a relatively soft launch
GhostZ is offline
Old 09-08-2003, 11:32 PM
neil350's Avatar
Vigi 3200 in my 93, great converter bought used of this board from Nick. You'll nail it rolling around and it insantly pulls to 3200 and takes off like a damn animal.
neil350 is offline
Old 09-09-2003, 07:47 AM
Derrick Redd's Avatar
1. Custom Built TC (Local) 9.5" 3,600 stall
2. Cam Motion 232/232 .560/.560 Pulls to 6,900 on the dyno
3. 2,900 on the brake
4. 12.09 @ 112.21 NA with a 3650 raceweight
5. 1.68-1.72 NA
Derrick Redd is offline
Old 09-09-2003, 08:00 AM
Kain's Avatar
1) Vig 9.5" 3200 stall, really loose converter.
2) CC306, shifting at 6500 rpm.
3) Never foot brake it, always let it flash. It flashes about 4000 rpm.
4) 12.2@109 (stock heads).
5) 1.65 60'
Kain is offline
Old 09-09-2003, 08:35 AM
Shon Herron's Avatar
I really liked my ST3500 from Yank. I would say the Vig 3200 or Yank ST3500 would be a good choice.
Get the smaller TC, it is less rotating mass therefore weight savings is a benefit!!
Shon Herron is offline
Old 09-09-2003, 10:34 AM
T/A lt1's Avatar
Vig. 2800 went 1.69 60's with a Hotcam and 3.42's in a 3700lb. car. I switched to the 3500 and it went high 1.5's to low 1.6's depending on conditons and retains lockup. The vigilante is the way to go for street/strip converters. I am going to a TH350 so I have mine forsale but iot's still in th car right now. iut will work in a 700 or 4l60 and it's a 9.5" converter. LMK if interested b/c it will be out later this week. Clint
T/A lt1 is offline
Old 09-09-2003, 11:45 AM
VINCELEE123's Avatar
Damn good thread!
look at the big brain on 12SCNDZ
you a smart mu***a
VINCELEE123 is offline
Old 09-09-2003, 12:11 PM
Ken95Z28's Avatar
(1) Yank ST3500
(2) Comp Cams 230/236
(3) 2200-2400
(4) 11.7's 114's
(5) 1.5's to low 1.6's
Ken95Z28 is offline
Old 09-09-2003, 12:31 PM
JKDZ28's Avatar
Midwest 3000 stall stalls around 2400-2600 with stock cam this is kinda with bald street tires
havent got to the track yet cuz i dont have any tires
JKDZ28 is offline
Old 09-09-2003, 06:20 PM
12SCNDZ's Avatar
Originally posted by Ken95Z28
(1) Yank ST3500
(3) 2200-2400
(4) 11.7's 114's
Ken,
Very nice web page. Thanks for the reply.
Frank
12SCNDZ is offline
Old 09-09-2003, 06:23 PM
12SCNDZ's Avatar
Re: Re: What 3000+ stall converters is everyone using?
5. 1.68-1.72 NA
Derrick,
Thanks for the reply. Is that a lock-up converter?
Frank
12SCNDZ is offline
Quick Reply: What 3000+ stall converters is everyone using?
