what is a 377
what is a 377
I read an article (Cam-O-Rama) in popular Hot Rodding. They built a LT1 and said it was a 377 with a 5.850 inch rod and an Eagle cast crank. I was wondering if this is a standard 4.000 in bore with a stroker crank or what the heck is it? Sorry if this is in the wrong forum. I tried to find it in calculations but no luck.
One of the mags ran side by side tests between a 383 and a 377, built the same, other than the cubes/strokes. It's the old stroke Vs RPM debate rearing its ugly head once again.
The results were predictable, more torque (383) Vs slightly more high RPM HP (377).
I've forgotten what mag I saw it in, but I'm sure I have it around here somewhere.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Jake
BTW, Bore x Bore x Stroke X .7854 x 8 will let you play with the CID of various combinaions, just in case you don't find a calculator online.
Jake
Jake
IgorT.455/406
Classic Engine Tech
06-13-2002 08:31 PM
