what belt to use after AC delet?
You can only delete the AC by replacing the compressor pulley with the "1LE" AC delete pulley. Once you do that, you will still use the stock belt routing, and may be able to use the stock belt length. Appearently they used more than one clutch pulley diameter, so some people find they need a slightly different length on the belt.
