What cable
#16
Re: What cable
I'm using a USB AKM cable myself, and it works flawlessly. My car's a '97, with a PCMsForLess OBDI conversion PCM. In terms of cable needs, it's just like a '95 - OBDI PCM with OBDII-style ALDL connector.
If your OBDI conversion PCM was done by PCMsForLess or MadZ28, the '95 cable will work for you.
#17
Re: What cable
Originally Posted by blazzinbird
ok here is what you do
go to http://akmcables.com/ic.htm and you want item number 2. if you are using a newer laptop you prob wont have rs232 cable port, so you need to get the usb kit cost is 90 dollars.
dont let anyone tell you it wont work cause they are fullof crap.
I have a 96 with a obd1 conversion, and it is what i use.
Glad to see they are making USB cables now, when I got my AKM cable all they came in was the R232 plug and I had to buy a USB adapter also.
