What can cause a backfire out the intake??
My car is backfiring out the intake, what can cause that besides plugwires being out of order??
Just looking for other possible causes, Just to be sure I don't miss anything.
Thanks in advance..
Thanks in advance..
Re: What can cause a backfire out the intake??
fuel pressure is fine, timing chain is fine.
I went to 42# injectors.
96' harness
94' PCM
Got a new tune, but backfire is still there, just pops real loud out of the CAI.
No vaccuum leaks either.....
96' harness
94' PCM
is the intake backfire bad on the engine? i just put a trick flow elbow and now the backfire sound is louder. what's causing it? we just had it tuned up last year.
I had a backfire out the intake ... long story short, scoped everything on the car with a dso... turned out to be the opti, installed a new one, problemo solved. Also, my misfire was only at a certain RPM... If that helps at all.
mine does it too but only when letting off at about 6000 RPM's. Could it be caused by tired valave springs which would cause valve float? I have new plugs, new coil, new wires, new MSD ignition. Hope it's not the opti. I could settle for the tired valve springs because I'm doing a Hot Cam Kit right after I do headers, which hopefully isn't that far off in the future. BTW, 96K miles.
You sure youre not hearing the exhaust... Ive got 133k on the clock and I dont get any intake backfires, not even after letting off at 6k. Then again, I don't let the throttle slam shut and leave it in gear. If you do that, then you get the exhaust popping sound.
I also had the same problem/ same results.
Noenav
04-30-2015 01:06 PM
Drtryder
04-22-2015 04:17 PM
F(ast)-body
02-26-2003 09:05 AM
