what can cause my knock?
I autotapped the car today, and i picked up 7 degress of knock at max... it would fluctuate between mid 4s to 7.0
i'm running on 93 octane, and my cam has a tune from ion...
what would cause the knock?
i thought it was false knock, but i capped my exhaust (closed the cutout) and still got the knock (it was actually worse)
what can this be from?
If you have headers, they could be the cause. Also a noisy valvetrain like aftermarket rockers and such could also cause false knock. Do you have a stock knock sensor, or an LT4 one? If you still have the stock one, I'd reccommend you pick up the LT4 version which is less sensitive.
If you've been running rich, your plugs could be fouled, which I've seen can cause pre-ignition.
When I changed my plugs after getting knock on nitrous, the knock went away. The old plugs were fouled.
whitehooptie
08-10-2015 07:02 AM
