what causes awful gas mileage??
I mean like 8-10mpg?? its got new plugs,wire,02's,opti,fuel pump. It runs real strong and i'm not sure if i filled it up all the way last time but it just seemed like the mpg went down when i filled it up today. I mean i didnt even think i could get that bad if i ran 150 all day long well whatcha think??
Possible causes for poor gas mileage:
...just to name a few.
- Defective O2 sensors.
- Exhaust leak.
- Fouled plugs.
- Bad optispark/ignition components.
- Lead foot syndrome.
- Underinflated tires.
- Low gears (numerically lower).
- Poor or incorrect PCM calibration/programming.
- Faulty injectors.
- Torn fuel pressure regulator.
- Emergency brake left on.
My mileage drops nearly that low in 25 mph and under city driving. But if your talking 45-65 range then you should be getting at least 15 mpg. You are using minimum 92 octane I hope. Something to check: When was the last time your fuel filter was replaced? An old/clogged filter can hurt mileage. Make sure your air-cleaner is clean too. Synthetic oil increase my mileage by about 1-2 (not sure how but it did) Just a few basics.
Re: what causes awful gas mileage??
BTW 8-10 mpg at a constant 150 would be exceptionally good.
08-24-2015 06:41 AM
CARiD
07-07-2015 08:19 AM
Campbellb48
07-05-2015 06:31 PM
