What is causing this trouble code?
63 Right oxygen sensor was open showing a steady voltage between 0.35 and 0.55 volts for 60 seconds after the engine had been running for at least 2 minutes.
What could be causing that? I think there's definitely something wrong with the engine. The exhaust is smelling kinda bad, and there's a loud ticking noise coming from the engine.
Re: What is causing this trouble code?
I agree with 93redbird. The O2 sensor should never be at a steady state during proper operation. The engine problems are probably a result of the ECM trying to correct for a bad O2 sensor reading, making the long term fuel trim to rich.
More than likely you have an exhaust manifold leak and that is what you are hearing. This could then be causing the poor readings at the O2 and the PCM is trying to correct it by richening things up. Swap the left and the right O2's to prove it. Then look for the tell tail black soot mark somewhere near the manifold.
ad356
04-11-2015 10:30 PM
armedtrigger
02-24-2015 08:30 PM
