What convertor for 650 rwhp w/4l60e ???
What are the big dogs running for a torque convertor? I've got a 3200 Torco and it's just not up to the job. Is the Vig good for that much hp?
Thanks in advance, TJ
i would go with a vig if i were u. but i was under the impression that a 4l60 wouldnt take that much power. i have a buddy that is running a 383 with one (dynoed 380RWHP) and the tranny would not make the 2-3 shift or 1-2 shift, with OBD1 or OBD2. most of the big dogs are running TH350/TH400's that are auto's
Ask the guys at Finish Line Performance. Chuck over there, he knows his stuff!!
Chuck@flp2win.com
Call Chuck Johnson 630-820-9294
Chuck@flp2win.com
Chuck@flp2win.com
Chuck@flp2win.com
I definitely second that!!
ok some shops have figured how to make the weak 4l60e last longer but no way will a 4l60e do it very long the best and most sturdy trans is the th-400 just take a look at the planitaries of all auto's and that alone will give you an answer
I got 56k on my 4L60e..not that I beat on it much.
If everyone believed in planet size you would not see them running those POS 2004Rs much...but they do
ANY transmission you run if your going to race it much should be freashened once a year or every 150-200 passes
Re: What convertor for 650 rwhp w/4l60e ???
Rich Krause
It's way too loose on the street. The car doesn't get moving until 2500 and then its still slipping. It also slips at WOT. I'd like a lockup convertor, but have an open mind. Even though the car has monstor power, it's primarily still a street car. I'd like it to move through traffic without having to go Nascar at every stop light. I think this particular convertor has always been pretty loose, even before the buildup.
