What could be the problem?
I can drive around for about an hour then it will start missing in the upper rpm's then slowly get worse to the point that I can barely do anything but idle. I can let it sit for awhile and cool off then it will run like a charm again. The only code i'm getting is low TP voltage. Any ideas?
Re: What could be the problem?
Look for things that can break down due to excessive heat.... IC Module and Opti optical sensor come to mind. Plug wire insulation weakens as it heats up. Coil??
fuel pump is not that old...it is a walbro 255lph from racetronix. Plug wires are fine. Nothing physically wrong with coil. I was also thinking opti but I don't want to tell that to myself yet. That is already the third one i've had in 5 yrs. keep the replies coming and thanks for the replies already
Have you considered spacing the ICM out from the head to reduce heat soak?
How do you know there's nothing "physically" wrong with the coil? Not sure how you would know the internal insulation was breaking down due to heat.
And you're sure the plug wires are not losing their insulating value at high temps?
Have you noticed any posts on these forums about short-term failures of the Walbro pumps?
Seems like you are sort of blowing off the suggestions.
And you're sure the plug wires are not losing their insulating value at high temps?.
Have you noticed any posts on these forums about short-term failures of the Walbro pumps?.
