What do you think about BBK cermaic caoted headers??
#16
Re: What do you think about BBK cermaic caoted headers??
I have some, I like them. If there cheap and all. I got BBK offroad pipe going to 3 inch and it did help it out a good bit. As soon as the headers were installed, you could gas on it and get it to kick sideways a good big easier. NO thats not a dyno run, but you can tell, you put them on there....
Good luck
Good luck
#18
Check those headers carefully when you get them - I had serious issues with them and sent them back, only to find their customer service sucked too.
#22
well if any of you guys are intrested i can get you soem barely used hooker longtubes witha brand new mufflex or y pipe for 425!!!!!!!!
#23
Originally Posted by jcolez28
[Spinner ]BBK doesnt make ceramic headers AKAIK. So unless they were coated elsewhere, they're probably chrome. Their shorties are a waste of cash. For 130 its better then nothing, but i'd save my money. You MAY see 10 hp.
Note: They weren't crap BBK shorties in GMHTP, either. Reread what I wrote
#24
I gained .3 and 3mph with a set of bbk shorties, but I would never buy them again. The welds are very sloppy and the bolt holes did not line up properly with the cyl head. I also had to modify the egr tube to fit into the header. 6 months later I was happy with the power per dollar I gained, but I was so pi$$ed off at the install that I didn't want to even drive the car for 6 months.
#26
I used the Dead soft alum ones...they have worked good, my friend at the same time put them on long tubes and his blew out qucikly but he had a 6 speed and a hot cam, maybe more pressure???
#30
I had 1406's blow out on both sides on my 95 9C1 (police pckg) LT1 caprice. The material thats on the metal shim in the middle was blown off the gasket on one side. The other side the metal part was almost totally gone on 1/2 the gasket!!! I did drive on a leaky gasket for a month before fixing it though. HUGE power gains after that leak was fixed. You dont want any leaks before your O2 sensors. Personally im trying to decide between the MR Gaskets and some of the percys "dead soft" aluminums now. Speed INC. Told me theyve seen problems with the aluminums too though. I was never a big fan of MR Gasket but their the only ones i havnt heard bad stuff about as far as the LT1 yet. So that will probably be my choice.
