What do you think about the Z06 MAF Conversion?
#16
What do you think of the 85mm Z06 MAF conversion
I got the information from this website:
http://pro-flow.com/tech%20info/sizing.htm
If the info there is correct that Z06 MAF will be the perfect size for my 400HP (flywheel) LT1 I wish to build some day.
Marvin
#17
Originally posted by MentalCaseOne
My bone stock LT1 (tb-bypass only) pulled 267grms/sec just a few days ago. I know I am not making near 320hp Are you sure 305 - 310 g/sec is all thats needed for 400hp?
That sounds awefully closed to my readings and I am bone stock.
267grms = 35.32 lbs/min
310grms = 41.01 lbs/min
thats only 6lbs/min more.
How did I pull 267grms fron a bone stock LT1? I removed the OEM plastic duct. Thats it. with the duct connected to the MAF it only pulls 227 grms... Removing that duct is good for 40grms/sec. I am thinking of building my own Cold Air.
Anyway correct me if I am wrong but are you sure you dont need any more grms/sec to produce 400 hp? sounds like I am awefully close to that number..
Marvin
Marvin
Now with all that said. YOu may be pulling 267 g/s, but you are under optimized in other areas, which affects the peak power. You could also say you are not making power as efficiently..
#18
That reminds me, without any other boltons, if I slap a low restriction catback I wonder what my hp is gunna shoot up to.
I am gunna calculate whats the max hp (flywheel) I could get from efficiently burning 267grms/sec at say 13.5 air to fuel ratio with a volumetric efficiency of lets say 85%? then I minus the tranny losses (at sea level 75 degree air temp). Maybe I will do a spread sheet.
I just like to play with numbers and later see if I came close to them. Good pastime Keeps me from getting into trouble. =)
Thanks for the info. very interesting.
Marvin
#19
Fun with Excel.. be careful, it can get to be time consuming playing with variables, but definitely a learning experience.
For trans losses, use 98/96/100/98% for gears 1-4 for gear efficiencies, and assume about a 8 ft-# loss through the trans. It is a rough rule of thumb, but useful for you purposes. COnvert the torque to HP using the engine RPM you are calculating for.
Use about 8% for power loss through the rear axle too..
All additive.
All additive.
#20
Should I get desktop dyno instead (cheat?) nawww
it would take the fun away. Hey that is some really good info you are giving me. That spread sheet is gunna be my spare time hobby. Thanks for the tip to convert to HP. I will do.
Marvin
tdigger9899
09-07-2015 10:56 AM
