what dual valve springs for the 306 cam?
Old 10-11-2007, 07:41 PM
mvvette97's Avatar
Just wondering what everybody is using with the 306 comp cam. I don't like the 918 that comp says to use because I broke 8 out of 16 on my LS1. What is a good dual spring?
mvvette97 is offline
Old 10-11-2007, 07:55 PM
blueformula350's Avatar
Why not go with some single beehives from pac?
blueformula350 is offline
Old 10-11-2007, 07:58 PM
mvvette97's Avatar
well I just don't trust the single spring anymore since they just about destroyed my LS1. I like the piece of mind with a daul spring
Old 10-11-2007, 07:59 PM
raroz28's Avatar
dual springs can break too.
raroz28 is offline
Old 10-11-2007, 08:01 PM
mvvette97's Avatar
very true but with a dual you have one more spring to hold the valve from bashing the piston. Normally both of them don't break
Old 10-11-2007, 08:08 PM
SS RRR's Avatar
Go to Comp's website and see what they recommend.
SS RRR is offline
Old 10-11-2007, 08:35 PM
9formula4's Avatar
They reccomend their products.
9formula4 is offline
Old 10-11-2007, 09:21 PM
hotrod18_69's Avatar
I'm using Crane 10308 spring kit.. I've used them on a few LT1 builds. .Worked great.. Never had any problems yet..
hotrod18_69 is offline
Old 10-11-2007, 09:23 PM
mvvette97's Avatar
Are they a direct fit on the stock heads?
Old 10-11-2007, 09:34 PM
Yes DIRECT FIT.. Just put them on..
http://store.summitracing.com/partde...0&autoview=sku
Old 10-11-2007, 09:35 PM
mvvette97's Avatar
Sweet, I guess I'll get those, thanks
Old 10-11-2007, 09:36 PM
Yup.. No problem..
Old 10-11-2007, 09:59 PM
Stl94LT1's Avatar
You can put a 1.460 OD spring on a stock head? No machining?
Stl94LT1 is offline
Old 10-11-2007, 10:03 PM
mvvette97's Avatar
what size is the OD on the stockers?
Old 10-11-2007, 10:16 PM
Stl94LT1's Avatar
1.334" for the stock LT4 spring.
Stl94LT1 is offline
Quick Reply: what dual valve springs for the 306 cam?
