What engine damage could this cause?
What engine damage could happen if you were ragging on a 96 supercharged 6 speed formula and went from 1st to 2nd gear back to 1st? I'm trying to get to the bottom of something that happened to my car when it went into the shop for some other work.
Brandon
Brandon
Re: What engine damage could this cause?
Originally Posted by 1racerdude
The only way it will have bent pushrods is if the valves hit the pistons which is very likely in that situation. If ya find them bent look for bent valves too.
I bent a set of stockers pretty well revving them high on spray. Maybe I need to pull the heads
u know.. if ur pulling heads anyway...... little machine work would really wake that cam up -
i sooo regret not doing my heads when i swapped cam and valvetrain..they were ready to just pop off- but of course i opted not to spend the extra money at the time....now to do i need to tear everything down again.
10-31-2016 11:09 AM
JasonD
08-23-2010 03:14 PM
guionM
10
09-08-2002 11:08 PM
JasonD
07-27-2002 08:57 PM
