What to expect from the 233/239?
I am about to be getting in on the Combination Motorsports Cam Kit GP. I believe I have decided to go with the 233/239 cam.
I will be running a K&N FIPK, Hooker Longtubes, offroad ypipe, 233/239 cam, 612 valve springs, Comp Cams 1.6 NSA 7/16 RRs, Comp R lifters, Comp guideplates, Racetronix Fuel pump, 30# SVOs, Fully built a4, 3200 VIG, and 3.73s.
Should that be a fairly stout combo? I am going to be on stock heads for awhile.
What are some tendencies of this particular cam? Is this the best cam to go with in my setup?
Hey mad wolf does your car burn rich at idle? You tuned mine and it burn extremely rich at idle but clears up when imm at full throttle. Can you tune that out of it? Plus i have to hold the pedal down about 3/4 of the way to get it to start? any suggestions? Anybody elses 233/239 do that?
