What to get next...please help
Ok i have around $4000 to put in the car and I`n not sure what to do. Just cant make up my mind so i am looking for oppinions. I know i will be getting a stall. I have a NX single EFI kit from my talon which i will probably use. My little bit of mods i have now are on the bottom. Help me , what should i do with the money. Thanks.
Thoughts so far:
long tube headers w/ true duels, NX wet kit, XE 230/236 cam???, inline fuel pump, SVO 30lb injectors, chip reprogramed by PCMFORLESS.
Thoughts so far:
Originally posted by FacelessZ
LT's, port your heads, XE 230/236 112*LSA, NSA 1.6 rr's, 3" header-back and you'll be set...
Don't forget about your traction...
