What if you sealed the opti?
Just curious. Let's say you're on your second opti (the old non-vented style) and you don't want to go through it again.
Before you install the new unit, you seal all seams, screws, terminal, vent holes (there are three on the bottom of a non-vented opti) with rtv sealant before putting it on.
Do you think this would be detrimental? If so, how?
Re: What if you sealed the opti?
Guess I didn't think of running a bead around the screw holes though.....
Originally Posted by Bryan 94 Z28
I ran a bead of clear RTW all the way around the edges of mine when I put it back together, haven't had a problem. I haven't checked inside of it since I did that, and that was about 4 years ago and its been running strong.
88IROC_Z
07-22-2015 11:38 PM
