What kind of RTV to use, if any??
I'm starting to re-assemble my motor after my cam swap. I've got Permatex UltraCopper for the intake manifold. As far as the timing cover gasket and WP gaskets, what kind of RTV should I use, if any at all?
Originally posted by Bud M
I think copper can be used anywhere you need RTV. Isn't it rated for the highest temp?
Originally posted by chasmanz28
yes but does copper sealant mix with gas
if useing it for the intake gasket?
Originally posted by shoebox
Not really any mixing going on, since it is primarily used on the end rails where there is no gas.
i wanted to use it on the both sides of the gasket to can i? I iknow it can be used on the end rails in the rear is where mine gave out
I have not heard of anyone complaining about any RTV breaking down from gas exposure (not saying it won't ).
I can't see any problem. The gasket is going to be doing most of the sealing anyway. Not sure that sealer is even required on the gasket.
Just my 2 cents on the Ultra Copper:
I had HORRIBLE experiences with that stuff trying to seal up my intake. I actually did my intake leak three times!!!
I ended up using the GM Assembly Adhesive (can't remember the part number) that is in the bulletin for the intake leak issue and then it finally sealed for me. The Ultra Copper would hold for a day or two then leak worse than before!! I used gobs of it like everyone kept telling me, but she kept leaking! The GM stuff was my saving grace. The tube costs around $8 at the dealer and is a little smaller than a Permatex tube, but the stuff works!!!
On the other stuff, I think I may use the same GM stuff. Also, JB Weld works great for exhaust manifolds!! Yea, you are laughing, but it does!!!
That is what worked for me, but good luck!
Never had problems with my intake manifold leaking after usin DA COPPER
Very funny!
I just could not get that crap to seal for me, not sure why, I did it the same way using the Copper or GM stuff and only the GM stuff worked (for me).
I did get real good at taking the intake off!! LOL!!! I got to the point where I didn't even have to label a thing!
