what is it like? 600+rwhp guys?
Old 12-21-2004, 06:28 AM
  #16
Nostang 96z's Avatar
Re: what is it like? 600+rwhp guys?
I don't quite have 600rwhp....well maybe on the 200 shot. My best dyno was 535rwhp on the 150 shot with 800 psi bottle pressure (best NA is 383rwhp). I have ET streets at all times on my car so it is not really scary. I can nail my car off of a stoplight and it will barely spin the tires NA on concrete. On asphalt I have to pedal it a little before I floor it. On the bottle it is a different story. I get scared in first gear. The car is so violent in first gear that if it hooks (will dead hook from 10 mph on concrete) it kind of makes you get butterflys in your stomach cause of the acceleration. The pull through second and third is nice but def not as scary as first gear. My car will not spin the tires in 2nd gear from a roll though but at 30 mph in first on asphault with the 100-200 shot it will smoke the tires and instantly redline. On concrete I have pulled the front tires from a 10 mph roll when it hooked and man that felt awesome (you can tell when you pull the tires cause when it comes down it shakes the stearing wheel and you can also hear the suspension bottom out). My car is all low end/midrange.
I did ride in a 835rwhp (32psi T88) supra before and it was amazing how much it pulled up top. We went from 60-140mph in no time. However, the bottom end range was weak because everytime he got on it it would spim once boost kicked in.
Later
Matt
Nostang 96z is offline
Old 12-21-2004, 09:32 AM
  #17
Z-RATED94's Avatar
Originally Posted by rskrause
On the street with street tires it doesn't feel much different than a car with somewhat less hp because all you do is spin the wheels. At higher speeds (100mph+) it's quite a rush though.
Rich
Rich, I think that last sentence goes very well with your avatar. As for me, I figure you have to have just enough HP to give yourself a little scare and a big smile once in a while. Otherwise what's the point?
Z-RATED94 is offline
Old 12-21-2004, 11:56 AM
  #18
Z97LT1's Avatar
I've been in several cars that make 600+ rwhp. On the street its not really that much different than ~450rwhp until you really start to break the law in a big way.
Z97LT1 is offline
carguy0119
04-11-2016 11:11 PM
blac94Z
29
03-25-2015 04:21 PM
steve10358
Middle Atlantic
03-20-2015 04:50 AM
mspennyhughes
11-28-2014 03:22 PM
Red97LT1
08-07-2002 05:45 PM
Quick Reply: what is it like? 600+rwhp guys?
