what makes higher numerical gears weaker
This was brought up in another post. I was under the long term understanding the higher numerical gears had more teeth on the ring, but smaller, therefore weren't as strong.
Another member gave me this info.
2.73s - 41 teeth on ring gear, 15 on pinion
3.23s - 42 teeth on ring gear, 13 on pinion
3.42s - 41 teeth on ring gear, 12 on pinion
3.73s - 41 teeth on ring gear, 11 on pinion
4.10s - 41 teeth on ring gear, 10 on pinion
4.11s - 37 teeth on ring gear, 9 on pinion <--
4.56s - 41 teeth on ring gear, 9 on pinion
He thought that they higher numerical gears were weaker because of the angle the teeth was different, thus making them weaker. Is that the correct reason, or is there something else which makes a lets say 4.10 weaker than the stock 3.42.
10-31-2016 11:09 AM
Lt1son
12-31-2014 01:35 PM
ChrisFrez
12-07-2014 06:01 PM
07-04-2005 05:00 PM
