What is the max IAC count
Neither shannon, but ever since i switched to the new TB, my BLMs split pretty bad. I used to be able to run them fairly close together, and have an at idle IAC of 25ish. Now i am running a 25ish IAC, with BLMS of 126/151 at idle .
If i close the blades any farther the IAC count will skyrocket. However i have not yet verified that the BLMs will pull together the way i want them to if i close the blades more, they may split even more, which would my fix problem as long as the IAC doesnt bottom out at 0.
Supposedly max counts are 255, but I have never seen any near that high on my car. Maybe about 140-ish is the highest I have seen, mostly in open loop and certain conditions with engine cool.
The higher the IAC counts are at idle, the less "range" you will have during driving when the counts normally go up.
Rough idle when cold.
Guys,
I am suddenly having a problem with rough idle when cold. I haven't done any work lately. I also have an oil leak that just started. It looks like the front main seal and maybe the intake manifold but I haven't confirmed yet.
I suspect a vacuum leak but can't tell for sure. Can you guys tell me if the freescan readings indicate any possible problems. The IAC looks high. Once the car warms up (5 minutes) or sooner if I punch it, the car idles fine. I have 2 sets of readings, engine cold (rough idle) and engine warm (idles fine).
TPS position-0, 0
Air flow-9, 7
IAC-71, 47
MAP-.417, ,388
Barometer-1.033
Left O2 volts-fluctuated between .124, .102 (fluctuating)
Right O2 volts-fluctuated between .155, .062 (fluctuating)
Mass Air Temp-27C, 25C (temperature dropped because I opened the garage door for fumes and it was cold outside.
Spark Advance-18, 18
Knock count-4706, 5443
Knock retard-0, 4
Integrator L-128, 128
Integrator r-128, 128
BLM contents-160, 160
BLM cell-16, 16
Thanks for the help...
Jeff
TPS position-0, 0
Air flow-9, 7
IAC-71, 47
MAP-.417, ,388
Barometer-1.033
Knock retard-0, 4
BLM cell-16, 16
Jeff
Re: Rough idle when cold.
BLM cell-16, 16
Jeff
BLM cell-16, 16
Jeff
