What mod to do next?
do you still have the stock coil? read of serveral guys picking up good sotp gains by upgrading their old coils. and those are only about $40 from summit.
second the pullies, so far i've had no problems with charging on my 96, even though i have a fan switch i see very little voltage drop with the fans on at idle.
personally i would ditch the hypertech chip and have someone burn you a better chhip designed for your setup...i think Madwolf is doing them now...for about $100 i think.
since you have full exhaust and a free flowing intake, you may pickup a few ponies from upgrading to a 52mm tb. [flamesuit on] i realize many guys will argue it's not worth the $$, but if you have your stocker ported by Nomad for $160 and you pick up 5-10hp, i'd say it's worth it.
CARiD
07-07-2015 08:19 AM
