what mph do you run out of gear with 4.11s?
Old 01-15-2008, 09:16 AM
Mtxz453's Avatar
what mph would you run out of gear with 4.11s on a m6? how about 3.73s?
Mtxz453 is offline
Old 01-15-2008, 09:19 AM
rich152's Avatar
What is your max rpm?
rich152 is offline
Old 01-15-2008, 09:20 AM
rich152's Avatar
Oh and what size tire?
rich152 is offline
Old 01-15-2008, 10:25 AM
Are you asking about "top speed" of the vehicle, or trap speed at the track?
Injuneer is offline
Old 01-15-2008, 10:26 AM
Colin91Z's Avatar
https://www.camaroz28.com/services/calcs/
Look at the one fourth from the bottom, titled: RPM and MPH Calculation
For my particular combo, I'm good for 132mph in 4th gear @ my 7000rpm shiftpoints. However, everyone's combo will slightly differ
Colin91Z is offline
Old 01-15-2008, 01:50 PM
Mtxz453's Avatar
top speed.. my car revs out stock still so i think thats around 5600 or so.. i wanna make sure if i have 4.11s i can still wind out on the thru way
Mtxz453 is offline
Old 01-15-2008, 03:07 PM
Mikey97Z's Avatar
Bowling's Vehicle MPH Calculator
Input Parameters Are the Following:
* Differential Gear = 4.11 to 1
* Transmission Gear = 1.00 to 1
* Tire Diameter (Inches) = 28.00
* Engine RPM = 5800
Computation Results:
# Computed Vehicle MPH is 118
118 in 4th gear at 5800 rpm
use this calculator https://www.camaroz28.com/services/calcs/rpmmph.shtml
Edit: You probably have 26" tires.
Mikey97Z is offline
Old 01-15-2008, 03:22 PM
Rising Phoenix's Avatar
In my car with 5800rpm shift points I'm just bouncing off the rev limiter right after I cross the traps in 4th gear.
edit: That's about 106, 107mph.
Rising Phoenix is offline
Old 01-15-2008, 03:27 PM
Zigroid's Avatar
http://www.pszweb.com/car/gears.htm
thats a nicer calculator.
1994 M6 car with 4.11s stock height (25.66") tires, at 5700 rpm is 106 mph in 4th
Zigroid is offline
Old 01-15-2008, 07:43 PM
slomarao's Avatar
our cars do 155 from the factory, with the 4.11 gear you only do 135,140. Thats if you around the factory power level. If you would have a 400rwhp car it would be different.
slomarao is offline
Old 01-15-2008, 11:14 PM
slomarao's Avatar
so are you saying the rear end ratios dont affect top speed?
slomarao is offline
Old 01-16-2008, 12:17 AM
Mtxz453's Avatar
sweet.
Mtxz453 is offline
Old 01-16-2008, 02:54 AM
sbs
sbs's Avatar
http://home.earthlink.net/~jonaa/topspeed.html
sbs is offline
Old 01-16-2008, 07:29 AM
al 96 Ram Air T/A's Avatar
Since I don't want to condone this behavior, I'll only speak "hypothetically"...
Assuming I tried to do this, I have had no problem getting up to 140 with my set up. And no, that was not the end of the line either. I was in 5th gear, and had plenty of power to continue. I don't think it will have any substantial decrease in top speed. 155 mph is usually done at redline in 5th gear. Having the higher numerical gear simply allows you to use 6th gear and be in the sweet spot of the rpm band.
So, to answer, at least 140...probably 145...and maybe even 150+.
But since I've never done this I don't know for sure.
FYI - please keep this kind of driving reserved for the track.
al 96 Ram Air T/A is offline
Old 01-16-2008, 12:03 PM
96 mikez28's Avatar
With bolt ons and 3.89's on a 26" tire i was going 155 in 5th at about 5900 RPM's, i would have kept going and tried 6th but i had to chill out and pass a truck lol
96 mikez28 is offline
Quick Reply: what mph do you run out of gear with 4.11s?
