what oil filter u runnin?
ive got a 94 trans am and i have flp headers for it. the driver side header wont fit cuz of the oil filter. i have on it right now a fram ph30 which is what is called for. what filter will work or is there a smaller one. plz help
Re: what oil filter u runnin?
K&N HP 3002, its about the best filter you can get for the LT1. $8.99 from Thunderracing, or $9.99 on the shelf at Pep Boys. And the extra money is worth it to me for the sweet 1" socket fitting alone Seriously, it is a very well made filter.
Originally Posted by 944v8inDFW
Greg is that the short one?
I run a k&n as I have read many times that the lt1 engines need oil flow, and the k&n is the highest flowing filter there is as compared to most others. I have 184k on my engine, and it is still a good running engine. Now running synthetic oll I'm sure also helps. Sure the gm oil filters rate well, but I feel l I want to do all I can to ensure there is always good oil pressure to my engine. I also change my oil anally, to ensure it is also clean. Doing these two things will get the mileage out of your engine.
later
andy
later
andy
I have FLP's on mine and have to use the stock short filter. A longer filter will rest against the collector on my car. I figure this will transfer heat from the collector to the oil filter. Don't need that.
