what options do i have in timing chains and gears for my 96 im doing a cc306 install?
Old 12-30-2004, 01:17 AM
  #16
speedmiser's Avatar
Re: what options do i have in timing chains and gears for my 96 im doing a cc306 install?
You'll need an electric WP of course, since the cam gear doesnt have the ability to drive the stock waterpump. Cam gear just unbolts, but you'll need a gear puller to pull the crank gear. I think you can borrow one from autozone with a deposit - one of my buds had one.
You'll also need to clearance the inside face of the timing cover. You can do this pretty easily with a die grinder and a dedicated alum bit. Put some grease on the chain after the timing set is installed, then test fit/grind, test fit/grind on the cover, until your not getting grease on the cover - then grind a little more to make sure everthing clears when things spin and heat up
speedmiser is offline
phoenix95
01-08-2015 02:44 PM
phoenix95
01-08-2015 09:14 AM
Queens94z28
12-20-2014 09:11 PM
siguy
11-27-2014 10:07 AM
GigaMp3z
02-20-2003 02:57 PM
Quick Reply: what options do i have in timing chains and gears for my 96 im doing a cc306 install?
