What Spark Plug Should I Use?
Old 06-07-2009, 11:43 AM
  #16
94zgreenmachine's Avatar
Originally Posted by ENRKyle20
and green. yea that would have been a good idea. For the most part this is the exact same motor that you ran with that pcm. If you still have the equipment you can just read a copy of the tune and send it (If you use tunercat). That would be cool :-)
Long gone. Been reprogrammed for the AI 200cc head/cam package
94zgreenmachine is offline
Old 06-07-2009, 11:44 AM
  #17
ENRKyle20's Avatar
I dont know if I am knocking yet. I the motor is almost built but not in the car. and the compression went up a little when I had the heads rebuilt because he shaved a little off the heads. said it needed it. who knows. anyway. I think I will use NGK TR6 seeing as green used those and besides the block, this is prety much his motor. identical pistons and rods, his heads and intake.. Thanks
ENRKyle20 is offline
Old 06-07-2009, 01:57 PM
  #18
ENRKyle20's Avatar
no prob green. Thanks anyway. Well this thread is complete I decided on a plug. Im sure I will have more questions when I start putting the motor in again. Lets hope I didn't forget anything this time like torquing a rod bolt. I had a helper there re checking everything this time so I didnt miss anything. I built the last motor in just a few hours alone not paying to much attention to detail apparently.
jwade88
06-14-2015 09:38 PM
jayblev95
06-07-2015 04:04 PM
blkWidow
05-03-2015 08:42 AM
nikko
04-20-2015 07:56 AM
94Z28LS1toLT1
02-28-2015 08:33 PM
Quick Reply: What Spark Plug Should I Use?
