What starter for new 383 daily driver with 11:1 ?
Old 10-20-2005, 03:18 PM
  #16
Harvey's Avatar
Re: What starter for new 383 daily driver with 11:1 ?
CANTONRACER, are you saying that if you upgrade to Kook's 1 3/4" to 1 7/8" to 3" collectors that you need this smaller starter? I am fixing to buy these headers and would like to know if in order change the stock starter out you need to take the header off, but with this smaller starter you can do it with the header on?
Wayne
Harvey is offline
Old 10-20-2005, 03:24 PM
  #17
CANTONRACER's Avatar
I was thinking about why I put a different starter on the engine...I don't want to give out false information.
I had forgot this...but my reasoning is because I went to a 163 tooth flywheel...which put the positioning of the starter farther out.
I found that the only starter that would fit is the one I bought.
If I had not went to a 163 tooth flywheel I bet the stock starter probably would have fit ok.
CANTONRACER is offline
Old 10-20-2005, 03:32 PM
  #18
LT4383's Avatar
I have Kooks with Canton pan
13.5 to 1 CR
LT4 starter new from dealer. I had to wrap it, but it works just fine.
LT4383 is offline
Old 10-20-2005, 07:48 PM
  #19
rawbutt's Avatar
if i have my stock flywheel, how many teeth does it have?
rawbutt is offline
timmy39120
05-08-2015 11:41 AM
87Aerocoupe
01-10-2015 07:27 PM
deadmanrunning
01-03-2015 01:12 PM
cmdeshon
12-12-2014 10:51 PM
Snoman73
11-17-2014 07:22 PM
Quick Reply: What starter for new 383 daily driver with 11:1 ?
